Configure multicast stream limitation members on ports of a specific VLAN to limit the number of multicast groups that can join a VLAN.
Enable multicast stream limitation on ports 2/1 to 2/3, and configure the maximum allowed number of streams to 6 for this interface.
Switch:1(config-if)#ip igmp stream-limit-group 2/1-2/3 max-streams 6
Variable definitions
Use the data in the following table to use the ip igmp stream-limit-group command.
Variable |
Value |
<0–65535> |
Configures the maximum number of allowed streams for the specified ports on this VLAN. The range is from 0–65535 and the default is 4. |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
